For more information on enabling database authentication, see Example: Enabling Database Authentication.database-client-policy <DATABASE-CLIENT-POLICY-NAME>
| database-client-policy <DATABASE-CLIENT-POLICY-NAME> | Specify the database-client-policy name. If the policy does not exist, it is
                  created. Once created and configured, apply this policy on the device hosting the database.  |
vx9000-34B78B(config)#database-client-policy DBClientPolicy vx9000-34B78B(config-database-client-policy-DBClientPolicy)#? Database Client Policy Mode commands: authentication Database authentication no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal vx9000-34B78B(config-database-client-policy-DBClientPolicy)#
| no | Removes an existing database-client-policy |
| database-policy global config | Documents database policy configuration commands. If enforcing authenticated database access, use this command to enable authentication on the database and configure the username and password. |
| use (profile/device-config-mode-commands) | Uses a database-client-policy in the VX9000's device or profile context |
| database | Drops or repairs a database. Also provides database keyfile management capabilities. If enforcing authenticated access to the database, use this command to generate, export, import, and zerzoise the keyfile. |
